V12 .NET API samples
Hello all,
I started playing around with the V12 .NET API samples in VS2010 and noticed something odd: the sample projects seem to ignore my breakpoints while debugging. When I manually attach VS2010 to the Bricscad process (in stead of using 'Start external program' in Project Properties) the breakpoints do work.
This must be one of the zillion check boxes below the surface.
Any clues anyone?
TIA
Arno van Eeuwen
Hi Arno,
Are you using .NET 4 with VS 2010?
Hi Daniel,
just using the samples as they ship: Target Framework = .NET Framework 2.0
