overruled!
Here's a sample using the new overrule classes in the .net API. All vertical lines are overruled to display as red and horizontal as blue. Of course you can set your own criteria, line length, circle diameter etc. To top it off its, surprisingly fast, I didn't notice any slowdowns at all. Powerful stuff really
Command class
[code]
using _AcAp = Bricscad.ApplicationServices;
using _AcDb = Teigha.DatabaseServices;
// alias
using _AcTrx = Teigha.Runtime;
[assembly: _AcTrx.CommandClass(typeof(Overruled.Command))]
namespace Overruled
public static class Command
internal static Overruler mDrawOverrule = null;
[_AcTrx.CommandMethod("doit")]
public static void doit()
if (mDrawOverrule == null)
mDrawOverrule = new Overruler();
_AcTrx.Overrule.AddOverrule(_AcTrx.RXObject.GetClass(typeof(_AcDb.Line)), mDrawOverrule, false);
_AcTrx.Overrule.Overruling = true;
else
_AcTrx.Overrule.RemoveOverrule(_AcTrx.RXObject.GetClass(typeof(_AcDb.Line)), mDrawOverrule);
_AcTrx.Overrule.Overruling = false;
_AcAp.Application.DocumentManager.MdiActiveDocument.Editor.Regen();
[/code]
Overrule class
[code]
// alias
namespace Overruled
else
[/code]
Woops, that code did not come out right. Here is the solution attached!.. now that we can : )
netload the Overruled.dll in the release folder and type doit : )
