fillet won't work in 3D context
Maybe I'm doing it wrong. Trying to place a fillet where an arc and line meet (both on same xy plane - 3D mode) and it ends up a skewed mess. In 2d mode of course no problem - tried doing it in 2D and then switch to 3D context and it again goes beserk. Now when filleting two lines no problem. Am I missing something?
I recently had the same problem. It turned out that the entities were not at Z zero. Once I fixed that, the fillet worked. Hope this helps.0
