Upload file to web using LISP
Hello,
I am trying to build an online licensing mechanism for use in AutoCAD/Bricscad and want to know if it is possible using Lisp fucnctions (calling ActiveX, or Windows system calls or whatever) to upload a file to a web-site.
For example, if I have created a file called LICENSE.TXT, and I want to upload the same to http://www.coordsys.com, can I do it completely using Lisp?
Of course, I would need a username and password to connect to my web-site. That can be provided into the Lisp program.
What I am looking for (or dreaming about) is the opposite of the GetRemote utility which can pull a file off a web folder and read it into CAD.
Regards
Rakesh
  • Hi Rahesh,
    Try that:
    [code](setq file (open "ftpfile.txt" "w"))
    (write-line "domain" file)
    (write-line "password" file)
    (write-line "cd //" file)
    (write-line "cd domains/domain.com/public_html/folder" file)
    (write-line (strcat "put " filename-to-sent) file)
    (close file)
    (dos_exewait (strcat "ftp -s:" "\"" "ftpfile.txt" "\"" " www.domain.com" ))[/code]
    Regards, Vaidas
  • Hi Rahesh,
    Sorry, Rakesh :)
  • Thanks, Vaidas,
    Did you try that code? Does it work?
    I discovered just now that there indeed is a PutRemoteFile method also available in the Utility collection of the drawing document. But, the downside as it appears to be is that the username and password must be supplied on a popu dialog box. I want it to be hidden and supplied internally by the program. need to check a little more. Perhaps, there is a solution somehow.
    Regards
    Rakesh
    http://rakeshrao.typepad.com
  • I'm using this code for my own needs. Add [code](write-line "binary" file)[/code] line before "put" if you need to sent executable.
    Regards, Vaidas
  • Now that lisp can send/retrieve data from .NET, you can use the framework to  create your password dialog and manage your internet connection.. just a thought
    I think Rakesh Rao wants to create a fully automated ftp upload mechanism without any dialogs or other user interaction. But I would love to see a sample of using the .net framework in lisp...
  • @Roy: Yes, I am looking at a fully automated Lisp way to push a file into the web.
    @Daniel: I have no exposure to .NET. So, I am looking at Lisp since that is the only tool I know well.
    Regards
    Rakesh
    Regards
    Rakesh
    [code]
    using System.Text;
    using System.Collections.Generic;
    using System.IO;
    using System.Net;
    //alias
    using _AcRx = Teigha.Runtime;
    using _AcBrx = Bricscad.Runtime;
    using _AcAp = Bricscad.ApplicationServices;
    using _AcDb = Teigha.DatabaseServices;
    [assembly: _AcRx.CommandClass(typeof(BcadMgdTest.Commands))]
    namespace BcadMgdTest
      public static class Commands
        static FtpStatusCode putFile(string url, string username,
                                     string password, string file)
          FtpStatusCode code = FtpStatusCode.Undefined;
          FtpWebRequest request = (FtpWebRequest)WebRequest.Create(url);
          request.Method = WebRequestMethods.Ftp.UploadFile;
          request.Credentials = new NetworkCredential(username, password);
          request.UsePassive = true;
          StreamReader sourceStream = new StreamReader(file);
          byte[] fileContents = Encoding.UTF8.GetBytes(sourceStream.ReadToEnd());
          sourceStream.Close();
          request.ContentLength = fileContents.Length;
          Stream requestStream = request.GetRequestStream();
          requestStream.Write(fileContents, 0, fileContents.Length);
          requestStream.Close();
          FtpWebResponse response = (FtpWebResponse)request.GetResponse();
          code = response.StatusCode;
          response.Close();
          return code;
        static string getWebPage(string url)
          StringBuilder sb = new StringBuilder();
          byte[] buf = new byte[4096];
          HttpWebRequest request = (HttpWebRequest)
          HttpWebResponse response = (HttpWebResponse)
          Stream resStream = response.GetResponseStream();
          string tempString = null;
          int count = 0;
          do
            count = resStream.Read(buf, 0, buf.Length);
            if (count != 0)
              tempString = Encoding.ASCII.GetString(buf, 0, count);
              sb.Append(tempString);
          while (count > 0);
          resStream.Close();
          response.Close();
          return sb.ToString();
        //(getWebPage "http://www.cadext.com/downloads/4334.txt")
        [_AcRx.LispFunction("getWebPage")]
        public static object getWebPage(_AcDb.ResultBuffer args)
          try
            if (args != null)
              List<<span style="color: #010001;">_AcDb.TypedValue> list =
                new List<<span style="color: #010001;">_AcDb.TypedValue>(args.AsArray());
              if (list.Count != 0 && list[0].TypeCode ==
                     (int)_AcBrx.LispDataType.Text)
                return getWebPage((string)list[0].Value);
          catch (System.Exception ex)
            _AcAp.Application.ShowAlertDialog(ex.Message + ex.StackTrace);
          return null;
        //(putFile "ftp://ftp.cadext.com/downloads/4334.txt" "username" "passwd" "c:/4334.txt")
        [_AcRx.LispFunction("putFile")]
        public static object putFile(_AcDb.ResultBuffer args)
          try
            if (args != null)
              if (list.Count != 4)
                return null;
              foreach (_AcDb.TypedValue T in list)
                if (T.TypeCode != (int)_AcBrx.LispDataType.Text)
                  return null;
              return putFile(
                (string)list[0].Value,
                (string)list[1].Value,
                (string)list[2].Value,
                (string)list[3].Value).ToString();
          return null;
    [/code]
  • @Daniel:
    I'm sorry for any confusion but actually I was thinking of using Lisp's com-capabilities to call .Net Framework components. This may not be possible however. My search has turned up web pages that discuss the possibility of creating com links to .Net-based programs, but I have not found any info about directly linking to the .NET redistributable.
    [code]
    ;;; Which library to import?:
    (vlax-import-type-library
      :tlb-filename "C:\\WINDOWS\\Microsoft.NET\\Framework\\v2.0.50727\\mscorlib.tlb"
      :methods-prefix "mscm-"
      :properties-prefix "mscp-"
      :constants-prefix "mscc-"
    ;;; A lot of functions but what to do with them?:
    (setq funcsNames (vl-sort (vl-remove-if-not '(lambda (a) (wcmatch a "MSC?-*")) (atoms-family 1)) '<))<br>
    ;;; What is the main object in the object model?:
    (setq sys (vlax-create-object "System.Object"))
    [/code]
  • FTP can be accomplished in LISP via a very simple (one line) script, I have accomplished this earlier.  BUT it is my opinion that you choose a different language/method as the security aspect is nearly non-existent with a pure LISP FTP implementation.
  • Hi Rakesh,
    what about making a call via a web browser? something in the form of:
    [code](startapp "explorer" "http://www.mysite.com/myproduct/?myuniquecode12345678")[/code]
    or
    [code](startapp "explorer" (strcat (chr 34) "http://maps.google.com/maps?q=C-616,+Natasha+Golf+View,+Domlur+Layout,+Bangalore,+india" (chr 34)))[/code]
    CAD Concepts
  • @Vaidas Guogis: I can get as far as logging in to the site, changing directories and all that but the PUT statement does not work. It seems to give the error : 500 Illegal port range rejected.
    Do you know why? How to solve this error?
    I did run up searches of the web but did not get a clear solution. They say "set it to passive mode", but I am already in passive mode. That is what 'quote PASV does.
    This is how my FTP script now looks like, if anyone wants to comment and suggest a fix.
    The test I am doing is simple. Just trying to copy a text file BCAD.TXT residing in F:/ to the public_html/sanjith/ims folder.
    //// Start
    open addr.com
    username
    password
    quote PASV
    type ascii
    cd public_html
    cd sanjith
    cd ims
    delete bcad.txt
    put f:/bcad.txt bcad.txt
    disconnect
    quit
    ////// End
    Sorry, Rakesh :)
  • @Rakesh Rao:
    Not tested, but try [code]put f:/bcad.txt[/code]
  •  You are most likely receiving a port error as you are attempting to upload to FTP but you are using a standard HTTP port.  Try to change the line referencing addr.com to ftp.addr.com and see what that does for you...
