Lisp Not working
Hello:
I am writing this lisp for a co-worker and it is not working.  The idea is to define the spacing of the snap and then to turn the snaps on, draw a linear dimension and then set the snaps back to their previous (before running the command) value.
If I step through the code one line at a time and paste the code into BC everything works, as soon as I load the lisp file and run it, the snaps are not set...
[code];Undefine the original dimlinear command
(command ".undefine" "dimlinear")
(princ "\nDEFAULT LINEAR DIMENSION UNDEFINED")
;Redefine the command
(defun c:dimlinear ()
  ;Save the current snap mode
  (setq psnapmode (getvar "snapmode"))
  ;Set the target spacing of the dimension lines
  (setq TargetSpace 0.375)
  ;Calculate the snap spacing
  (setq SnapSpace (* (* (getvar "userr1") (getvar "userr5")) TargetSpace))
  ;Set up the snaps
  (setvar "snapunit" (list SnapSpace SnapSpace))
  (setvar "snapmode" 1)
  (command ".dimlinear")
  ;Reset the snaps
  (setvar "snapmode" psnapmode)
  (princ)
)[/code]
  • Hi Scott,
    your lisp isn't working because it doesn't stop at the .dimlinear command, but carries on. You can see this by placing a few flags
      ;Set up the snaps
      (princ "\ngot here1")
      (princ "\ngot here2")
      (princ "\ngot here3")
      ;Reset the snaps
      (princ "\ngot here4")
      (princ)
    )[/code]
    Try adding some pauses to the .dimlinear e.g.
    [code](command ".dimlinear" pause pause)[/code]
    CAD Concepts
  • Thanks Jason, I just could not see that one yesterday, I will make the changes...
