Copy Multiple
Copy multiple is no longer on by default in V12.1.10, has anybody else noticed this?
In new installation or in update? I have update and all is as must be = copy multiple.0
@ Scott: you can this behaviour inside the copy command:
: co
Select entities to copy:
Entities in set: 1
Current copy mode: Multiple
Enter base point: mOde/:
Enter second point: :
Enter second point: Undo/Exit:0 -
Improved version of the command history in my previous post (with correct pointy brackets):
: co
Entities in set: 1
Enter base point: mOde/<Displacement>:
Enter second point: <ENTER to use base point as displacement>:
... Final attempt:
: COPY
Entities in set: 1
Current copy mode: Single
Enter base point: mOde/Multiple/<Displacement>: O
Enter a copy mode: Multiple/<Single>: m
Wether multiple copies or a single copy are created is controlled by the COPYMODE system variable, which can be set either at the command line or in the Settings dialog box. The value of COPYMODE is saved in the registry and thus applies to all drawings. If COPYMODE = 1 (ON), a single copy is created, if COPYMODE = 0 (OFF) multiple copies are created.0
Thank you for the replies, not too sure what happened, but it suddenly set copymode to 0 - no lisp routines were used during the drawing. Upon restarting the variable was set back to 1...0
