Shortcut for switching between windows in BC ?
Is there a keyboard-shortcut available to switch between windows (drawings) in Bricscad ?
In Excel e.g. you can easily switch between worksheets by pressing Ctrl+PgUp or Ctrl+PgDn
Maybe the same shortcuts can be used in Bricscad (if there are no other available yet).
According to me, it would be very useful
Thanks in advance
ctrl+tab same for both Bricscad and excel.
Ctrl+PgUp and down doesnt fork for me in either program. /Patrik
Philip: Try Ctrl+Tab and Ctrl+Shift+Tab to move through open windows. A better option is the DocTabs add-on Daniel Marcotte created. See DocTabs in the applications area for more info.0
Ctrl+Tab does nothing in Excel or BC for me...PS : I work with Excel 2007 and BC v120
Indeed, with Ctrl+Tab you can switch between drawings (different files). That's correct, I use this shortcut also.Maybe my initial question was not described very well... Here is attempt n° 2 :-)When you have only 1 drawing open, you have at least 2 sheets at the bottom of your screen (model space + paper space).I was wondering how you can easily switch between these sheets (in the same file).E.g. switch from model space to paper space (and back).Thx0
