Ctrl - Shift - Middle button activates 3d sphere view rotate -- how to turn this off?
How can I disable the ctrl-shift-middle button function from turning on the 3d view sphere command? I can't find it in Customize... but I suppose it is there somewhere.
Thanks.
I'll second that request. I find it annoying and not working in 3D would love to disable it too.
Guess its not diffciult to overcome except the years of habitual use without it.0 -
Hi John,
I don't think you can disable, but you can define Ctrl + Shift + Middle to something else, which may be of more use to you.
To redefine your mouse buttons:- type CUI at the command prompt.
- Select the Mouse Tab.
- Expand the Mouse Button sequence you want to change, such as Shift-Ctrl-Click.
- Select the Middle Button option (will currently be blank).
- Right click and select Insert Button.
- Customise to what you can, such as ^c^c for cancel.
- Pick Ok when you are finished to return to the command line.
Regards,Jason Bourhill
Redifine-ShiftCtrlClick.png0 -
Thanks -- I never would have figured that out. It is not very intuitive.. I got into that dialog box before, but would never have guessed that the middle line is the one you use to define the middle mouse button!0
