Rotate drawing in layout tab
I have a project with multiple sheets (layout tabs). How do I rotate the drawing in one without affecting the others?
Hi Scott,
you can do this by rotating your view inside the viewport on your layout. There are a couple of ways to do this:- Inside the viewport use the UCS command to rotate your ucs about the z axis, then use the PLAN command to align your view to the new ucs.
- Inside the viewport use the DVIEW command, select some of your drawing, then use the TWIST option to rotate your view.
Regards,Jason Bourhill
Please read the topic 'Rotating the Display in a Paperspace Viewport' in the Bricscad Help under User Guide / Viewing your Drawing / Paperspace Viewports.0
