Print filled text
When I try to print text in TTF format, I allways receive the outline of the text in one color and width; and the fill color like on screen. How can I obtain the same color end outline of the text when printing.
  • The best way is to set the color of your text to white (7) on screen and map 7 to plot as 7 (black). It is a bug that I dare say they said that it will be fixed in next release in around a week from now.The other way to do it if you are just plotting a black and white plot is to set your printer to just plot in black. I haven't tried this but should also do the job.Hope it helps a little.
