BrXNET - Deleting a block definition
Hello all, I noticed following while using BRXNET:
When I want to delete a block definition from the drawing, I only need to delete the correct BlockTableRecord from the BlockTable, and I don't need to check for references in the drawing. Right?
Must say it makes life pretty easy!
TIA,
Arno van Eeuwen
