An unexpected error occured.
I am working with BricsCad Version 9. During attaching an External Reference file into the main drawing, I got a message dialog box as follow:
"An unexpected error occured. The application become unstable. It is recommended to save your work to a temporary file and restart the application."
I have tried to do the recommended mention above. However, the above dialog box always appear while I am attaching external reference file.
Does anybody have experience with this?. I am using Windows 7 with 64 bit.
Any input will be appreciated.
Best regards,
Sugia Mulyana.
Best regards,
Sugia Mulyana.
Perhaps you can run AUDIT in both each file and see if that helps.0
