Error in .NET concerning the Layer Property of a Solid 3D Object ???
                                  in 3D Modeling
            Hi all,
I am trying to change the Layer of a Solid3D sphere using following code :
[code]
// ODA
using Teigha.Runtime;
using Teigha.DatabaseServices;
using Teigha.Geometry;
// Bricsys
using Bricscad.ApplicationServices;
using Bricscad.Runtime;
using Bricscad.EditorInput;
namespace TestingLayer
public class Commands
[CommandMethod("testlay")]
public static void CreateSolidSphere()
Document doc = Application.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
Transaction tr = doc.TransactionManager.StartTransaction();
using (tr)
BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
BlockTableRecord btr = (BlockTableRecord)tr.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite);
Solid3d s = new Solid3d();
s.CreateSphere(50);
s.Layer = "20";
btr.AppendEntity(s);
tr.AddNewlyCreatedDBObject(s, true);
tr.Commit();
}[/code]
The statement s.Layer = "20"; brings the error in the attached screenshot below
I use a .DWG with the Layer Name "20" and the Layer already created !
If i comment (deactivate ) the above statement the sphere gets created and no problems arise.
In AutoCAD the statement doesn't throw any errors and the sphere is changed to layer named "20"
I attach the .DWG as well.
Could anyone outhere check it out before I create a Bug-Support request !
Regards, Thanks
Konstantin
[code]
// ODA
// Bricsys
using (tr)
s.CreateSphere(50);
s.Layer = "20";
tr.Commit();
}[/code]
Regards, Thanks
Konstantin
            I attach the assemply to reproduce the error easily...! i hope0
Either add
s.SetDatabaseDefaults(db);
or move
s.Layer = "20";
after
cheers
            thanks a lot Daniel...both suggestions have worked !
It is interesting though, that none of them is needed in AutoCAD !
Greetings0 -
GreetingsGreat, glad it worked : )
Acad is doing a certain amount of handholding behind the scenes, whereas TD_MGD is a bit pickier. If you step back and think about it, there is a certain amount of ambiguity in assigning a layer to a new non database resident entity. Acad assumes you mean the working database whereas TD_MGD wants to know 'which' database in the case that the coder is working with multiple databases.
Cheers
            Ja...I thought that it is something behind the scenes, something
having to do with a new and not yet database resident entity.
Thanks for explaining this...
Greetings0
