V12.1.16
in Linux
Mandriva 2011
Guys, should the new release install along side of 11.3.16? or does this cause a problem ? Bricscad V12 creates /opt/bricsys/bricscad/v12 and populates it with the install files. But it seems some files seem to be missing. Knowledge base attempts to address these issues here
https://www.bricsys.com/common/knowledge/topic.jsp?id=305
But thus far no luck. V11 continues to work ok.
I have both installed and had never considered if that may be an issue.
The only real bug i have left is the text menu.
They are already working on that.
Still it's a good question.0 -
Mandriva 2011 64bit
After reinstalling V11 and V12 both versions are up and running on the same box. As I am using Radeon Graphics, 3d is not yet fully working in V12, but support advise they are working on this.
