wrapping the text in circle or window /polygon region
i want to wrap the selected text within a selected circle or window or polygon. i don't want the text to go beyong these objects.
is there any command or lisp code available to achieve this feature?
thanks in advance.
  • Dear Kotesh,
    This is already possible in the GeoTools software that you are using.
    http://www.4d-technologies.com/geotools/manual/text_tools.htm#ENCLOSE
    You can wrap it around using a CIRCLE or a bounding box rectangle.
    However, from today, the same command has been transferred to CADPower (http://coordsys.com/cadpower)
    Regards
    Rakesh Rao
    http://rakeshrao.typepad.com
  • dear rakesh,
    i have seen the command in geotools for wrapping the text i.e
    Enclose with [ Box/Circle/Slot ] :c,
    once the text is ready and if i execute the above code, circle is drawn around the text. afterwards if i increase the size of text, it is going beyond the circle drawn. i want the circle also to proportionately expand to accommodate the text.
    second thing is is there any difference between powercad and geotools?
