Layer tools
Has anyone had any problems with layer tools? I am using v12. Everything works except copy and move to layer. What is strange is that when the "All" box is checked, it does work (copies or moves all entities to another layer). I have spent a lot of time trying to get this to work (including reinstalling), am I missing something?
Hi John,
Can you elaborate a bit more on what you are trying to do? There is lots of different methods ways that you could do this. Maybe if you can give the command name, and a screen grab
Regards,Jason Bourhill
I'm trying to copy a group of entities from one layer to another (but leave the originals on their layer). When this tool is working it makes short work of the process.0
@ John:
Are you using this add-on: http://www.bricsys.com/common/applications/application.jsp?app=335&apploc=528
Or are you talking about a built-in command/feature?0 -
Yes, I am using BCADTools. Sorry for not being clear.0
Dear John,
indeed, I can reproduce the problem - sorry for the bug;
I will quickly fix the issue, and update the package; can be
downloaded + reinstalled from Application Catalog then.
Will keep you updated then.
Many thanks & many greetings0 -
Thanks..0
