single drawing compatibility mode
do bricscad having this function or any function similar to this function? This is because sometime when i keep open many program when the time i want close it will ask me weather want to save the program or not. Sometime it will make my computer hang.
Hi Eric,
the answer currently is no. If you go to Settings -> Settings and search for SDI it will say the option is read-only as it its "yet" to be implemented.
If you do a search on the net (for AutoCAD) you will see a few examples of how to run things like scripts in a MDI.
Regards,Jason Bourhill
Bricscad-SDI.png0 -
ok thank you. Hope that the feature will be implement soon0
