Step and gCode export plugin request.
Hi Devs,
It will be so nice to see these export options available in the next versions of Bricscad4Linux.
For .step there are lots of resource, but for gCode I can recommend an startpoint opensource plugin for Inkscape:
http://www.cnc-club.ru/forum/viewtopic.php?f=15&p=101
Bobcam is a very good example for cnc and 2d cutting.(plasma, water, etc...)
http://www.bobcad.com/products/milling
Hope project leader be bitten by the bug ;-\
  • Ditto on the .step
    i know i can export to sat/acis and then use a 3rd party converter, but sure would be nice to export an assy all at once straight to step.
  • I asked to Sycode plugin developer if they will support Linux ? (soon or later)
    My contact from the sycode form -----------------------------------------------------
    Query      :
    Hi sir,
    I would like to know if your Bricscad plugins will support the version
    12 in Linux.
    Best regards.-
    They reply yesterday with this:-----------------------------------------------------------
    No.
    Regards
    Pramila Mayekar
    I think Bricsys should develop this feature inside Bricscad. Leave these features to plugin developers is not good idea.
    Regards.-
