How to tell if there are Dim overrides?
In the Dim panel of the Drawing Explorer there is always an entry 'overrides', even if there are no overrides. As far as I know the only way to tell if there actually are overrides is to make a dimstyle current: if there is a warning there are overrides, if not there are no overrides. Is there another, more elegant and easier, way to tell if there are dim overrides?
  • There is:
    : -dimstyle
    Current dimension style: M_M_100
    Current dimension overrides:
    DIMCLRT     1 (red)
    DIMDLI      0
    DIMFXL      1
    DIMFXLON    Off
    DIMJOGANG   45
  • Thank you Knut.
