lineweight
is there a feature in intellicad that corresponds to "lineweight" in autocad?
  • I am not familiar w/autocad, but if you are looking to set line weights for plotting, use the plot dialog setup for map line weights to colors (e.g., if you have a b&w plotter, set red to plot white -actually this gives you black - and specify the desired line weight to associate with this color.)
