Multiple Leader Arrows
In the absence of Multileader what is the best way to create an additional arrow to the leader ? It seems that the default leader arrow does not have a node or point to connect to if we wish to add an arrow. I notice that we can create a single arrow with-out text using the "None" option instead of text. But connecting it to a existing Leader with text is difficult. Autocad did not have Multi Leader for many years. We simply added arrows to our leaders to point to multiple elements. We could pick the appropriate node on the end of the underline beneath the text and the arrow looked as if it was connected to the same leader. Any ideas on how to appoach this ?
This may help someone. Allways draw the leader with a small horizontal section on its end. It can be very small - it does not matter. This creates the node or point for your next leader. If you simply draw an arrow at any angle and allow Bricscad to insert its horizontal shoulder the node or point is not created at a suitable point that a second arrow can use. You must draw it yourself. But it can be small as you like. When you draw your second or third arrow you can snap to this node - then follow the prompts and select "none" for text, creating multiple leaders.
