SetDatabaseDefaults()
When creating new objects in .NET I would like to set the layer to an existing layer. But when using
Dim sol As Solid3d = New Solid3d()
sol.SetDatabaseDefaults()
an error "No database" occurs.
Is is not supported?
try passing an instance of your database in the argument, if you don't have an instance handy, you can use HostapplicationServices.WorkingDatabase
That works!
Thanks Daniel.
