HANGIN' HAIRS
Minor problem - probably with source code...The cross hairs hang - requires a REDRAW or a REGEN to get ride of the 'old hairs'.! Intellicad98, Ver 5.00.2614.3500IS.Cipher strength 40-bitCipher strength ? ?Thanks...
The cross hairs during drawing dont fade out I have had to Redraw to remove them verry annoying. My pc is a win 98Se Pent 3 with 528 meg of ram 16 meg video card. Is there a setting to change redraw times events? that I cant find Any help would be appreciated Thanks
This problem is worse with some graphics cards, particularly ATI Rage cards. If your problem is the crosshairs "ghost" when you move the cursor, this can be eliminated by reducing hardware acceleration in the windows display driver settings. A lesser annoyance is when they "stick" after certain commands. I have not found any way to remove this problem.
I have had this very same nuisance and think that it is atiming/redraw glitch in the display list server of Icad. Althoa cursor of 100% screensize is better for me, I did find thatsetting it to 99% (in Tools/Options/Crosshairs), gets rid of the problem on my system (Matrox G200 AGP video card)...I had an ATI Rage128 and took it out cause that was reallybad with Icad.
AN UPGRADE TO 2.2.0027 NEARLY ELIMINATED THE PROBLEM OF JANGIN' HAIRS. THE PROBLEM RETURNS SPORADICALLY AT TIMES. CAN'T FIGURE OUT IF IT IS RELATED TO CERTAIN COMMANDS, LOADING/USE OF LISP, ETC. IF I CAN NARROW IT TO A CAUSE OR TWO I WILL LET CUST. SUPPORT KNOW. I WILL ALSO CHECK INTO THE SUGGESTION OF REDUCING THE CROSS HAIRS TO LESS THWN 100" OF SCREEN WIDTH AS SUGGESTED BY RSaarkko at ajrs@telus.net - thanks to all
Does setting your Viewres to fast zooms help this or affect it any?
