Objects+Text -> Block with editable text
Hi, i have been trying to learn my self how to turn a bunch of
objects and text objects into a single block where i can edit
the text of the object to simplify the work when i CAD for work.
However, i have yet managed to do so.
Could someone please write a simple to follow guide, those little guide/help text ive found
did not help me, or did not work out as intended.
/Regards Stefan G.
We are using Bricscad Pro V11.4.6 build id 30718 rev 23066 at work if that changed the how to make the objects with editable text.0
If by editable text you mean attributes:
In the Bricscad Help there is a section called "Working with Attributes" that should get you started. There is even a movie.
Contrary to the movie I usually select the attributes definitions one by one to ensure the correct order in the block definition.0 -
Contrary to the movie I usually select the attributes definitions one by one to ensure the correct order in the block definition.Thank you, now it seems it works like its intendet to, i just now opened a new project and followed the help guideand now i managed to make it as one block with attributes.Feels wierd it did not work 2 days ago when i tried to do the same thing.0
