EPS Files
Hello all, anyone of you knows a lisp or a program that can open into Bricscad V12.1.22.1 ESP files do? Thanks for the info
  • If you mean Encapsulated Postscript:
    Convert the file to pdf if you just need an overlay or to dxf if you really need to import, look here.
  • Hello,
    thanks for the Antwort.Ich would like to import directly into EPS Bricscad.
