Compiling ObjectARX code with BRX
I'm getting a lot of
[code]acrxEntryPoint.obj : error LNK2019: unresolved external symbol "enum Acad::ErrorStatus __cdecl acdbEvaluateFields(class AcDbObjectId const &,int,wchar_t const *,class AcDbDatabase *,enum AcFd::EvalFields,int *,int *)" (?acdbEvaluateFields@@YA?AW4ErrorStatus@Acad@@ABVAcDbObjectId@@HPB_WPAVAcDbDatabase@@W4EvalFields@AcFd@@PAH4@Z) referenced in function "public: void __thiscall AcDbMyEditorReactor::update(void)" (?update@AcDbMyEditorReactor@@QAEXXZ)[/code]
and similar mostly about the MFC methods (except this one all other errors are about MFC methods).
Any thoughts, somebody?
Indeed, acdbEvaluateFields() is not yet implemented in BRX ...
Can you put your compiler + linker output as a SupportRequest, please ?
Then we can verify and schedule for implementation ...
Many greetings !0 -
I post it with the name "MFC and Field API errors"0
