pgp file
in Other
how would one find the pgp file? i would like to edit my aliases that are defaulted from my company's.
Randy, do you want the LOCATION of the PGP or do you want to MODIFY it? To change your command aliases, try the CUSTOMIZE command, Aliases tab. Here you can edit or add command aliases. Notice also that across the top of the Customize window is the location of your main pgp file. If you have additional CUI files loaded, in the Menus tab you can select the custom menu (below the BricsCAD Main and Context menus) and the location of these files will be visible in the Menu Group panel below.0
