Export to EPS-file
I'm searching for a way to export a drawing from BC to an EPS-file.
I need this for high quality printing (for brochures and leaflets).
Can this be done by Bricscad or by any freeware convertor ?
Thanks in advance.
I'm searching for a way to export a drawing from BC to an EPS-file.I need this for high quality printing (for brochures and leaflets).Can this be done by Bricscad or by any freeware convertor ?Thanks in advance.If you export as PDF, your printer/graphic designer should be able to use it to create a brochure.Sander0
Hi Sander,thanks for the quick respons.The PDF-export can be used of course but the quality (sharpness) is not high enough.And I think you can not change the quality setting of the PDF-export...0
Does your DWG got raster images?0
PdfCreator is able to create many output formats (apart from the obvious PDF). Amongst them is EPS (level 1,1.5,2 and 3). So you could ty to print to PdfCreator (while setting PdfCreator's output format to EPS). Havn't tried it myself, but perhaps this would produce the required quatility?0
