vla-settext problem
Hello,
I'm have some problem with a simple task of layer name's assignment to a cell as a Field object.
[code](vla-settext (vlax-ename->vla-object (car (entsel "\nSelect Table:")))
(strcat "\%<\\AcObjProp Object(\%<\\_ObjId " (itoa (vla-get-ObjectId (vlax-ename->vla-object (car (entsel "\nSelect Object:"))))) ">\%).Layer >\%")
)[/code]
Any idea is appreciated.
Regards, Vaidas
)[/code]
Regards, Vaidas
            Forgot about comparison... this code adds a linked field in AutoCAD as expected but converts it into a text in Bricscad.
And sorry for my Engrish, I can't edit posts herein
Thanks, Vaidas0 -
            Dear Vaidas,
as far as I recall, ODA / TD core does not yet support assigning a field value to attributes, by setting the text content (no parsing is done here).
You might send us a SupportRequest about this ?
Many greetings !0 -
            Thank you, Torsten, I was doubt on format I'm used.
Regards, Vaidas0
