Batch Plot Error
I just purchased Bricscad Pro V.12. I am trying to use the batch plot. Every time I load drawings into the batch plot list, I get this error, "DeviceCapabilites() failed for printer printername.pc3" (where printername.pc3 is the actual pc3 file last used in the dwg.).
No matter what pc3 file I use, it does this. My pc3's are imported from Autocad. So I thought that might be the problem. I deleted them and remade them in Bricscad. I still get the same error.
The only way batch plot seems to work is if I don't use pc3's and use the printer directly. While this may seem like a good workaround, I have changes to the default settings of each printer/plotter. I can't utilize these without the pc3's.
Does anyone know what is going wrong or what I am doing wrong?
Any help is appreciated,
Dave
