an unxpected error occured- while trying to make blocks
When going ' block' selecting the symbol I want to make a block, then close and save, 'an expected error occured. the application became unstable' comes up and it doesn't save the block.
But most of the time this doesn't happen and it makes the block perfectly, Very strange.
But once it has happened once to that symbol, it happens every time I try to make it into a block.
  • Perhaps try typing "wblock" (write block) and follow this procedure until the Bricscad developers figure out how to correct this issue...............
  • What version of the software are you running - I don't create many blocks but just tried to create a block from a rectangle in V12.1.20 with no issues...
    What is the result of the audit command if run on the drawing that is crashing?
  • The result is that sometimes it trys to resave the drawing, and somethimes nothing-just doesn't make the block.
    It is the last version of V11 before they updated to V12. i noticed when i delete the hatching and re hatch it, i can create a block, so there is something in the hatching that the block tool doesn't like?
  • I use that version. Haven't had that issue, but I make sure Associative Hatching is off because I would sometimes open a file and discover the hatching had found new boundaries since I last worked on it. A lot like associative dimensioning. System stability-wise, V11 is very stable for me.
