Field Variables
I set up a title block with fields using dwgprops, fabulous feature I just found. Anyways does anybody know a system varuiable that will update a reference in the title block that relateds to the drawing saved name? For instance I used the ctab variable to update the page number with that of the paper space tab.
Also how about copyright? Or a list of what each variable is?
