Snap to extension in paper space
Hi
Does any one have a problem getting the 'snap to extension' snap to work in paperspace?
This snap works as suggested in model space, however in paperpace the first two crosses apear then nothing of the third interescting cross.
Clearly I am using this in assisting dimensioning.
Many Thanks
Barrie
  • The extension snap is a great tool, but it does not work in the situation that you have described (snapping to model space entities in paper space). You should send in a support request.
