Toolbars
Any one else having trouble with their toolbars displaying? A number of toolbars of both my own creation and ones from commercial add-on products seem to have quit. If I uninstall the add-on programs and reinstall them they will be visible until I restart Bricscad, then they are all gone again. I am using V12.2.6 and the add-ons are geotools v12 and dpcogo v12.
Thanks,
Vince Popish
I have not experienced any problems with my additional CUI files.
To troubleshoot your problem try this:
1.
Unload empty partial menus. If you have been experimenting with customizations you may have accidentally created one. They can cause problems when adding further CUIs.
2.
Change the order in which you attach your CUIs.
Try loading CUIs that have been created from MNU files last.
You may have to do this step by step:
a. Revert to defaults.
b. Load menu A.cui.
c. Exit and restart.
d. Is everything OK? Then load B.cui.
e. Exit and restart.
f. etc.
Remember that if a CUI fails to load properly the problem may be caused by the previous CUI.0 -
Roy:Thanks, followed your suggestions and got it working.Vince0
