Unable to Copy In V12.2.6
Just installed V12.2.6, I selected an entity to copy picked my base point and pick the second point, this is what I receive on the command line:
Select entities to copy:
Current copy mode: Multiple
Enter base point: mOde/:
Enter second point: :
No active transactions
And no objects are copied.  Any suggestions?  I also cannot see the entity (tried with a block and a line) while dragging - I checked drag mode and it is set to Auto, tried ON and no change.  Ran audit on the drawing a bunch of errors were fixed but same issues afterward...
Just tried the drawing in BC 11 and everything works properly, on a side note those entities that I copied did not copy - I thought that they may have copied but did not display or something along those lines...
  • Do you have the same problem if you start a dwg from a default template or is the problem restricted to a specific dwg?
    FWIW: I have not had any problems with the COPY command in V12.2.6.
  •  I just opened up a new drawing (using my custom template) and the copy command works.  I'm wondering what is up with my drawing, a restart will probably help, followed by a copy of all entities out and paste into a new drawing.  I will post back and let you all know the results...
  •  Just a quick update, I wblocked all of the entities out of the drawing, created a new drawing and inserted the block; upon testing the issue was resolved....
