Jigging a line with unexcpected results.
Hi there,
to test a function I have jigged a regular line and writen the angle to
the command line to check the lines returned angle.
The problem is it counts OK from 0 > 180, but when you go past that it then counts
backwards from 180 > 0.  obviously I was expecting 0 > 360 degrees.
Has anyone else seen this, is it a bug?
Imports Teigha.Runtime
Imports Teigha.DatabaseServices
Imports Teigha.Geometry
Imports Bricscad.ApplicationServices
Imports Bricscad.EditorInput
Imports Teigha
Imports Bricscad
Public Class Temp
    Inherits EditorInput.DrawJig
    Dim EndPt As Point3d
    Dim myPR As PromptPointResult
    Dim myPER As PromptEntityResult
    Dim StPnt As Point3d ' Centre of selection
    Function StartJig() As PromptPointResult
        ' Get Doc
        Dim myDWG As Document = Application.DocumentManager.MdiActiveDocument
        Dim myEd As Editor = myDWG.Editor
        Dim GetPntOpts As New PromptPointOptions(vbCr & "Select insert:")
        Dim GetPnt As PromptPointResult = myEd.GetPoint(GetPntOpts)
        StPnt = GetPnt.Value
        myPR = myEd.Drag(Me)
        Do
            Select Case myPR.Status
                Case PromptStatus.OK
                    Return myPR
                    Exit Do
            End Select
        Loop While myPR.Status <> PromptStatus.Cancel
        Return myPR
    End Function
    Protected Overrides Function Sampler(ByVal prompts As JigPrompts) As SamplerStatus
        Dim jigOpts As JigPromptPointOptions = New JigPromptPointOptions(vbLf & "Select insert point:")
        myPR = prompts.AcquirePoint(jigOpts)
        If myPR.Value.IsEqualTo(EndPt) Then
            Return SamplerStatus.NoChange
        Else
            EndPt = myPR.Value
            Return SamplerStatus.OK
        End If
    End Function
    Protected Overrides Function WorldDraw(ByVal draw As GraphicsInterface.WorldDraw) As Boolean
        ' Get Doc
        ' Endpoint of Drag Line
        Dim CntLine As Line = New Line(StPnt, EndPt)
        If CntLine.Angle > ToRad(0) And CntLine.Angle <= ToRad(180) = True Then<br>            CntLine.ColorIndex = 1
        Else
            CntLine.ColorIndex = 4
        End If
        draw.Geometry.Draw(CntLine)
        myEd.WriteMessage(vbCr & CntLine.Angle.ToString)
        ' Dispose
        CntLine.Dispose()
    End Function
    _
    Public Sub Roundabout_ExitArm()
        Try
            ' Start Jig
            Dim myJig As New Temp
            Dim SelPt As PromptPointResult
            SelPt = myJig.StartJig()
        Catch ex As System.Exception
        End Try
    End Sub
End Class
  • My guess is you need to use the line's Delta and a reference vector, see
    [code]
        [CommandMethod("doit2", CommandFlags.Session)]
        static public void doit2()
          AcAp.Document doc = AcAp.Application.DocumentManager.MdiActiveDocument;
          Matrix3d xfrm = doc.Editor.CurrentUserCoordinateSystem;
          PromptPointOptions ppo = new PromptPointOptions("get next Point");
          ppo.UseBasePoint = true;
          ppo.BasePoint = doc.Editor.GetPoint("get start Point").Value;
          PromptPointResult ppr = doc.Editor.GetPoint(ppo);
          Line line = new Line(ppo.BasePoint, ppr.Value);
          //use a reference vector
          double ang1 = line.Delta.GetAngleTo(
            xfrm.CoordinateSystem3d.Xaxis, xfrm.CoordinateSystem3d.Zaxis);
          //no reference vector
          double ang2 = line.Angle;
          doc.Editor.WriteMessage("\n{0}-{1}", ang1, ang2);
    [/code]
    Also, don't create a new line in each call to WorldDraw as it will use up resources, make the line a member of your class, or better yet, use the geometry provided in worldDraw
    Cheers : )
  • Thanks for the help,
    that does provide a work around, but shouldn't the correct angle come from the line?
    Is this a bug?
    Cheers again,
    Martin.
