Workout Centroid of closed polyline
I have a lots of closed LWpolylines (Light Weight type but if your routine works on old style POLYLINES then I can still use it) that are basically rectangular in shape but may also have more than 4 sides sometimes (irregular closed polies). I need to have a routine that will work out the center of the polygon so that I can insert a piece of text in it such as "E" for Electrical. My e-mail is av@computersupport.itgo.com Thanks in advance.ANDREAS.
