hatches and ucs
there has been a big bug with the hatches and blocks while working on a user defined coordinate system. all the blocks are inserted aligned to WCS and the hatches are filled at a reference angle to WCS. it is too much time consuming rotating everything after the insert or giving an many-digit numbered angle.Did anyone solve the problem?I thought this would be solved but the problem is still thereWhen will Bricsnet solve this problem
