stretch command
after I open the crossing window, and choosþng the base point, I move the mouse to the streching direction and write the dimension from the keyboard but it doesnt work. is it the only way we use stretch command only by writing "@100<180" etc....?
  • My stretch command works fine apart from the moving instead of stretching broken lines (hidden, phantom, etc) when crossed through the open section of the line. This is an old bug they still have not fixed.
