Properties bar
I open the properties dialogue in, yet it doesn't show up. maybe its off in space somewhere. Any thoughts to get it back?
            Maybe change your monitor resolution so you can find it and re-dock it?
(I've had similar problems with other proggies in the past)0 -
            Robt: thanks for the thought, no good though. I still cannot find the bar. Its open, but no where to be found. Its tough because I don't know how to change things any other way.If anyone has any thoughts, let me know.0
            The easiest way I know of to reset the position of the various panels and dialogs is to create a new profile using the Bricscad User Profile Manager.
OR:
The properties panel position and floating / docked state appear to be stored in your user profile. At least for v12.2.8 it is saved in the registry at:
HKEY_CURRENT_USER\Software\Bricsys\Bricscad\V12\en_US\Profiles\[Your Profile Name Here]\Toolbars\PROPERTIES
You can change the position of the panel by changing the first two values. I just tried "show floating 0 0 240 500" and the panel appears at the top left of the screen.
If you are not comfortable editing the registry (or don't know what it is) I would suggest:- use the Bricscad User Profile Manager to export your user profile to a file
 - open the file in a text editor (i.e.: Notepad, not a word processor)
 - search for PROPERTIES under the Toolbars section
 - change the values
 - save the file
 - use the Bricscad User Profile Manager (with Bricscad not currently running) to import the file as a new profile or delete the existing one if you want to keep the same name.
            @ Chad,
per Gregs post I would try creating a new profile to see whether it resolves your issue. This is quite easy to do, have some information here on how to do this:
http://www.cadconcepts.co.nz/creating-a-new-user-profile/
Floating windows can be a real pain in Windows, its not just a Bricscad thing. Most commonly it is struck by laptop users who have a dual monitor set-up. Some windows, such as the Drawing Explorer can be retrieved by pressing Alt + SpaceBar + M on the keyboard, then use the keyboard arrow keys to retrieve. Unfortunately this technique won't work for the Property Bar.
Regards,Jason Bourhill
 - change the values
 - save the file
this saved my hiney, thank you Greg0
