Bricscad - open office integration
I am looking to do the same on linux. I know VBA/COM is not supported on linux so I'll do as much as I can on lisp.
I'm not sure how to setup the interprocess communication between bricscad and openoffice. Initially, I want to export attributes to openoffice calc for editing and then import them back into bricscad.
Any advice would be helpful at this stage.
I am slowly switching over from Autocad to bricscad on linux. In my current Autocad setup (on windows) I have integrated MS office with Autocad using VBA.
Any advice would be helpful at this stage.You might want to explain what you want a bit better - you're being quite vague. From what I understand though the easiest way would probably be to save the attributes as a csv file and then load them afterwards.0 -
Appologies for being vague. But you're on the right track though. But instead of exporting to a csv first, the data is directly placed into a spreadsheet. This is currently done using vba/com under windows
I have columns set up for attribute names and a row for each block. My current program creates that format and places an attribute string into a spreadsheet cell. Attribute names are stored in the first row and object handles are stored in the first column.
So, for each block/text/mtext , the program searches each row for a matching object handle. if the handle is found, that row is over-written else appended to the rows. Similarly with each attribute,it seaches the column names (row1) to find the right column. if the name doesn't exist it is appended . Each attribute is then associated (in a table form) with an object and an attribute.
Hope that makes sense.0 -
Well the best I can suggest is the following. There might be a better way that I don't know of so anyone can correct me if I'm wrong. - Export the attributes as a CSV file (perhaps call it ".tempcsv" because the . will make it hidden in linux) - Open the CSV file with calc with something to the extent of code[/code]. Keep in mind that I don't actually know what the command is this is just speculation. - Edit any attributes you want to in calc and then save. - Reload the CSV file with a new command in Bricscad. I wrote a CSV loader for AutoLISP a while ago so you can probably base it on that: http://code.google.com/p/cencad/source/browse/trunk/readcsv.lsp . (Please bear in mind i was a terrible programmer when I wrote this and it was the first code I ever wrote in AutoLISP) That should be it. Good luck and I'll help if necessary. Regards, Daniel
Hi Phill,Did you ever give SQLitelsp a run? You could put all your data in database tables, then run queries on them to do updates or populate your attributes. There's a lot of good database managers out there for SQlite that should be able to import CSV's as well.A link with some of the functions https://forum.bricsys.com/discussion/11607Download link(bottom)https://forum.bricsys.com/discussion/16442Cheers : ) Dan
