Artisan in V12.2.8
Has anybody got it to work?
If I install and then run the command artisan as suggested on the applications page of the Bricscad website I see the following:
[code]Error loading "C:\Program Files\Artisan For Bricscad\Artisan.brx": .
Unable to recognize command "ARTISAN". Please try again.[/code]
DemandLoad failed due to dependencies problems !
Application : Artisan
Description : Artisan for Bricscad
Module Path : C:\Program Files\Artisan For Bricscad\Artisan.brx
I looked in the support paths and noticed that X:/AddBit was added along with a blank line above and below this entry - I don't have an X drive. I am trying this on Windows XP with Bricscad V12.2.8
Any ideas?
I did not try personally ...
but empty support pathes and also non-existing support pathes should
be removed from support path settings, that's safe, for sure.
Besides, the Registry DemandLoad entry has the fully specified module path
to Artisan module - so it is not a problem of support pathes, likely.
When you Drag & Drop the file "C:\Program Files\Artisan For Bricscad\Artisan.brx"
from i.e. Explorer into Bricscad, do you also get an error message (when loading
is successful, it returns the name of the module itself).
I will try installation of Artisan also.
Many greetings, Torsten0 -
If i drag and drop, or use appload/arxload to load the .brx file...[code](ARXLOAD "C:/Program Files (x86)/Artisan For Bricscad/Artisan.brx")* (arxload) : can not LOAD filenil[/code]I must be missing something with the installation, but I am really looking forward to trying it!0
I'm in contact with LightWorks ...
there seems to be a minor problem with finding + loading some component files ...
You might have a look for folder named "CTB" in "Program Files (x86)" ... you can then
add that ".../CTB" folder as support path, this *might* help.
But LightWorks is preparing new installers, to overcome those issues ...
Many greetings !0 -
We are currently looking in to this issue and hope to provide everyone with a new installer soon.0
Awesome news, I am looking forward to giving Artisan a go!0
