dimension precision problem
i has change my dimension precision to 0.00 but when i draw a circle with diameter 10mm i wont show 10.00. If i draw a circle 10.05 then i will show 10.05. Any other setting i need to set?
            Primary Units / Suppress dim zeros / Suppress Trailing Zeros ?0
If you type Dimdec and set it as "2" it should work as you want.
I can't remember which setting in the dim properties dialogue does that, but I have an issue in V12 with legacy files where Dimdec is set at "-1" which is no longer accepted. I believe "-1" caused radial dimensions to follow the units precision of linear dims and that might be related to your problem, Eric.
I am hopefully waiting my SR and still on V11 because I don't want to change every dimstyle in every old file I open in V12.
