Losing my Paperbackround while using Realistic Visual Style in Layout Viewport
When i have 3D Objects and want to make a Layout for printing I am losing the white Paper(background) when I use Realistic Style (high quality - with materials) in Paperspace Viewport.
When i Use just conceptual Style (Schattiert) all works good but when I want to switch to realistic Style in one viewport so the background of Layout becomes just grey and i do not have my paperspace anymore.
I attached 2 pictures:
Bild 1 is shown normal - Bild 2 shows result when i switch to realistic style.
Is there any known issue?
You can upload images. Just use the Add attachment(s) feature below the text box.
There is an image button above the text box which can be confusing. That button is for images that already "exist" on the WWW.0 -
Yes i know about the button below the text box, I also can browse to the pictures on my computer and attach, but they do not load and i see just a red cross:( did already try different file formats (png / jpg)
Yes i know about the button below the text box, I also can browse to the pictures on my computer and attach, but they do not load and i see just a red cross:( did already try different file formats (png / jpg)0
Now it works???? Is there a morning buck????:)))
Ok so here is the second picture
Can i delete my answers in forum which i do not need or which are published wrong?
Normally the form starts uploading the attachment as soon as you have selected it in the file browser.
Afterwards you see a list with attachments beneath the 'add attachments' box and you can still choose to remove a wrong file before posting.
Your pictures have uploaded perfectly (eventually), so for the red crosses you see, it'll probably be either a browser or connection problem.Now it works???? Is there a morning buck????:)))
You can't delete wrong or double posts yourself, but don't worry, we deleted them for you.
If you keep having problems with using the forum, you can always file a support request.0
