Table style with top border only on header does not work
If this is a bug, I can send in a support request. But perhaps I'm doing something wrong:
I want to create a table where the "header" cell type as defined in the table style dialog box has a line on the top of the cell only. There is an icon for this option in the table style dialog box (in the "cell frame" category). But when I click on this icon, the table looks just the same as if I click on the icon for an underline in the cell -- no difference in the preview or in the actual table.
Am I doing something wrong, or is this a bug?
Thanks.
Hi John,Yep looks like you might have found a glitch .. I'd file a support request
Dan
You are probably not doing anything wrong. There are definitely some bugs when it comes to setting cell frames. If your tables have a title you can try setting the bottom line of the "Title" cell type instead.0
I was checking Acad010 and it has similar behavior, you can't even change the horizontal header grid lines, even though they're options for it. I bet it's the draw order of the grid lines.. there are some subtle differences, but you should be able to create what you need by changing the title
Cheers
