VBA / ViewDirections / ZoomCenter
div>
Can be usefull to define a Viewpath. At first we define some Views 1 ... N (ViewCenterPoints / CameraPoints / ViewDirections) .
Then there will be activate each View 1 ... N and ZoomIn with the ZoomCenter command - with a ZoomWidth.
To test it and describe the problem here [--> end of text] are two VBA-Routines - witch are running seperate.
Routine01 / TopViews / 'ViewPoint-Vertical = + 90°
Routine02 / IsoViews / 'ViewPoint-Vertical < +90°
Both routines are in principe identical. The only difference is under Pt.2a) Definition CameraPoints
ZoomCenter works only correctly with a "ViewPointSetting H=270°V=+90°"
If we use the Tool SetViewpoint -  before start Routine01 - can be set a other Viewpoint, f.E. H=210°V=+90°,
The ZoomCenter works then with this Horizontal-Viewpoint H<>270° rightly.
The Problem is:
The same Horizontal-Viewpoint-Setting H<>270° cannot be activate from VBA .
If we place the command [ThisDrawing.SendCommand "VPOINT R 240 90 "] in Routine01 - the result is always with a "ViewPointSetting H=270°V=90°".
Problem:
The ZoomCenter works rightly only for the 1. View ?
But Views 2 ... N  have results - that all Objects move more and more outside the Display.
The ZoomCenter don't 'zoom here to the "ZoomPoint ZCPt()".
Who have experience to solve this problem- so that the VBA-ZoomCenter works for user-defined ViewDirections ?
Best Regards
Peter Busch
'TestRoutine01 / TopViews / 'ViewPoint-Vertical = + 90°
 Public Sub ViewDirection_ZoomCenter_TopView()
   On Error Resume Next
   Dim ObjEnti As AcadEntity
   For Each ObjEnti In ThisDrawing.ModelSpace
     ObjEnti.Delete
   Next
   ThisDrawing.ActiveSpace = acModelSpace
  'Active Viewport1
   Dim AVPort1 As AcadViewport
   Set AVPort1 = ThisDrawing.ActiveViewport
  'NbrOfViews 1 ... N
   Dim NbrOfViews As Long, ActiveView As Long
   NbrOfViews = 10  ' >1 & < 100
  '1a) ViewCenterPoints 1 ... N
   Dim ViewCtr(99, 0 To 2) As Double
  'StartPoint / X-Y
   ViewCtr(1, 0) = 0.5: ViewCtr(1, 1) = 1
  'Point2...N / X-Y
   For ActiveView = 2 To NbrOfViews
     ViewCtr(ActiveView, 0) = ViewCtr(ActiveView - 1, 0) + 20 * Rnd + 5
     ViewCtr(ActiveView, 1) = ViewCtr(ActiveView - 1, 1) + 20 * Rnd + 5
   Next
  'Elevation
   For ActiveView = 1 To NbrOfViews
     ViewCtr(ActiveView, 2) = 1
   Next
  '1b) Show ViewCenterPoints
   Dim CenterPointObj As Acad3DSolid, CtrXYZ(0 To 2) As Double
   Dim TextStr As String, TxOb1 As AcadText
     CtrXYZ(0) = ViewCtr(ActiveView, 0)
     CtrXYZ(1) = ViewCtr(ActiveView, 1)
     CtrXYZ(2) = ViewCtr(ActiveView, 2)
     Set CenterPointObj = ThisDrawing.ModelSpace.AddCylinder(CtrXYZ, 2, 2)
     CenterPointObj.color = acGreen '(Nbr + 3) * 10
     CenterPointObj.LAYER = "0"
     TextStr = Str(ActiveView)
     Set TxOb1 = ThisDrawing.ModelSpace. _
                 AddText(TextStr, CtrXYZ, 2)
     TxOb1.LAYER = "0"
     TxOb1.color = acRed
     TxOb1.Lineweight = acLnWt035
     TxOb1.Alignment = acAlignmentLeft
     TxOb1.TextAlignmentPoint = CtrXYZ
   Next
 'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
  '2a) CameraPoints 1 ... N
  'Top_View / Vertical = +90 Deg.
  'CameraPoint - for each ViewCenter / 20m over the ViewCenter
   Dim ViewCam(99, 0 To 2) As Double
     ViewCam(ActiveView, 0) = ViewCtr(ActiveView, 0)
     ViewCam(ActiveView, 1) = ViewCtr(ActiveView, 1)
     ViewCam(ActiveView, 2) = ViewCtr(ActiveView, 2) + 20
   Next
  '2b) Show CameraPoints
   Dim CameraPointObj As Acad3DSolid, CamXYZ(0 To 2) As Double
     CamXYZ(0) = ViewCam(ActiveView, 0)
     CamXYZ(1) = ViewCam(ActiveView, 1)
     CamXYZ(2) = ViewCam(ActiveView, 2)
     Set CameraPointObj = ThisDrawing.ModelSpace.AddSphere(CamXYZ, 1.5)
     CameraPointObj.color = acMagenta  '6 * Rnd
     CameraPointObj.LAYER = "0"
                 AddText(TextStr, CamXYZ, 2)
     TxOb1.LAYER = "0"
     TxOb1.color = acYellow
     TxOb1.TextAlignmentPoint = CamXYZ
   Next
  '3. Calc ViewDirections // ViewCam(...) ---> ViewCtr(...)
   Dim ViewDir(99, 0 To 2) As Double
   Dim dX As Double, dY As Double, dZ As Double
   Dim Dist As Double
     dX = ViewCtr(ActiveView, 0) - ViewCam(ActiveView, 0)
     dY = ViewCtr(ActiveView, 1) - ViewCam(ActiveView, 1)
     dZ = ViewCtr(ActiveView, 2) - ViewCam(ActiveView, 2)
     Dist = Sqr((dX * dX) + (dY * dY) + (dZ * dZ))
     ViewDir(ActiveView, 0) = -(dX / Dist)
     ViewDir(ActiveView, 1) = -(dY / Dist)
     ViewDir(ActiveView, 2) = -(dZ / Dist)
   Next
  '4. Set ViewDirection & ZoomIn with width ZWid
   Dim ZCPt(0 To 2) As Double, ZWid As Double
   Dim VDir(0 To 2) As Double
   ZWid = 30
    '4.1
     VDir(0) = ViewDir(ActiveView, 0)
     VDir(1) = ViewDir(ActiveView, 1)
     VDir(2) = ViewDir(ActiveView, 2)
     AVPort1.Direction = VDir
    '4.2
    'ZoomIn
     ZCPt(0) = ViewCtr(ActiveView, 0)
     ZCPt(1) = ViewCtr(ActiveView, 1)
     ZCPt(2) = ViewCtr(ActiveView, 2)
     ZoomCenter ZCPt, ZWid
    'ThisDrawing.Regen acActiveViewport
   Next
 End Sub
 'Routine01 / TopViews / 'ViewPoint-Vertical = + 90°
  'TestRoutine02 / IsoViews / 'ViewPoint-Vertical < +90°
  Public Sub ViewDirection_ZoomCenter_IsoViews()
p class="MsoNormal" style="margin: 0cm 0cm 0pt;">    Dim ObjEnti As AcadEntity
</font>
  • 'TestRoutine02 / IsoViews / 'ViewPoint-Vertical < +90°
         ObjEnti.Delete
       Next
      'Active Viewport1
      'NbrOfViews 1 ... N
      'StartPoint / X-Y
      'Point2...N / X-Y
       Next
      'Elevation
       Next
         TxOb1.LAYER = "0"
         TxOb1.color = acRed
       Next
      'Iso_View / Vertical < +90 Deg.
         ViewCam(ActiveView, 0) = ViewCtr(ActiveView, 0) - 5 - 5 * Rnd
         ViewCam(ActiveView, 1) = ViewCtr(ActiveView, 1) - 5 - 5 * Rnd
         ViewCam(ActiveView, 2) = ViewCtr(ActiveView, 2) + 10
       Next
         TxOb1.LAYER = "0"
       Next
       Dim Dist As Double
       Next
       Dim VCtr(0 To 2) As Double
       ZWid = 50
        '4.1
        '4.2
        'ZoomIn
       Next
     End Sub
