How to stop configuration popup
I have a problem where each time BricsCAD starts up  - I get a warning that says to configure using '%'s because a program I deleted called cadprofil is no longer in use.
This happens each time I open the program. Any ideas on how to stop this popup, I no longer use CADprofil, and I think I removed any links or references to it in the program.
Thanks,
Eric
  • I would first check these files:
    on_start.lsp
    on_doc_load.lsp
    To find their location you can use these pieces of code (paste on the command line):
    (findfile "on_start.lsp")
    (findfile "on_doc_load.lsp")
  • Thanks Roy - On Start had the file set to load.
    Eric
  •  Try to do as below
    1. Open CADprofi Configuration --> Select BricsCAD V12 --> Restore CAD
    2. Open BricsCAD --> Tools --> User Profile Manager --> select " Defualt"
    3. Open CADprofi Configuration --> Select BricsCAD V12 --> Configure CAD
    4. Open BricsCAD again
