background mask in Mtext
Hi
When I open the properties of some Mtext  and
I change background mask option to "Yes"  & Choose the "use drawing background colour", (my background colour is black)
I get a black mask over the text & background when I print.
Using MText properties, is there any way of just masking the linework behind the Mtext with no printed background?
thanks
Peter Cooke
  • Hi Peter,
    The method you're using should work. Are you printing to PDF, or direct to a printer? Some PDF printers struggle with background masks / wipeouts. If this is your problem try changing to a different PDF printer.
    CAD Concepts
  • Thanks Jason,
    No It happens when sent to any printer
    I've tried pasting the text into an empty drawing,
    then printing, same result
    although if I don't apply a ctb or stb to it, I do get the mask
    so, do I need to change my Plot style table so that the colour of my background doesn't print?
  • Also tick "use drawing background color" do not choose black, or try choosing colour 255 wich should be the same.  Both work for me with and without cbt. 255 doesn´t look good on screen. tested in 12.2.7
    Cheers / Patrik
  • Tried both suggestions......
    same result here, I'm in Ver 12.9
    also tried changing background to white & mask to colour 255 and  also "use drawing background colour"
  • I'm experiencing the same thing. Everything looks good in paperspace. All of the background masks appear black in plot preview and plots.
