several issues
Hello Users!
i have a question concerning editing
mtext-blocks by using the ddedit
command or by simply doubleclicking
the mtext-block.
When i try to edit a textblock, the editor appears,
but the cursor is not visible / marking text parts is not visible too.
I can mark text and edit / change text,
but i cannot see the changes. Textstyle is simplex 8-35
Restarting bricscad is a workaround.
I think this is a Bricscad bug as the same thing happens
to a collegue at a different working station.
i have another question: sometimes objects like endless lines disappear.
They only reappear after regenerating the drawing. How does that come?
thank you
S. Scheiding
Sorry, double post.
Hello Users!
the mtext-block.
Restarting bricscad is a workaround.I think this is a Bricscad bug as the same thing happens
thank you
S. Scheiding
