Initializing Bricscad with a Batch File
I would like to include some command line switches when starting Bricscad, it seems the most effecient way to do this would be to create a batch file to initialize Bricscad. (otherwise each time Bricscad is updated/downloaded the custom ICON is lost)  Anyone operate Bricscad in this manner, I cannot get the code right in the batch file to properly function.
I would like to incorporate the /p and /t switches.  I can get all to work perfectly in a customized ICON, however as stated above this ICON gets deleted when Bricscad is updated.
Bruce
  • Are those icons associated with the desktop link taken from Bricscad.exe ?
    If you assign an icon from outside Bricscad, it should alwaqys remain ...
    And/Or, rename you desktop link (installer might recreate that desktop link) to somewhat unique, And/Or uncheck the installer option "Create desktop icon ..."
    I hope, one of these hints will help ?
    Many greetings !
